SergioPontes_36's avatar
SergioPontes_36
Jun 24, 2018
Difference between command CPCFG and REBOOT VOLUME
Hello everyone,
           in an upgrade or downgrade process of image or hotfix software, I would like to understand the difference between the **cpcfg** and **reboot volume** commands. If the commands are for different situations, what does each one do exactly? For example, after installing an image, which command establishes the default system image?
  •  tmsh reboot volume
    reboots the system to the specified volume. The current volume saved config is not transferred during this process - the new volume boots with whatever config it had when it was shut down.
    cpcfg
    copies the saved configuration from a source volume to a destination volume (as long as the destination version is the same or newer than the source version).
    K14724: Using the cpcfg command to copy a configuration from one boot location to another
    By default, when you install a new version into a new partition, the current volume saved config is also transferred during the install. When you boot into the new volume, you will have the existing configuration (as it was when you installed the volume). You can control this behaviour:
    K13438: Controlling configuration import when performing software installations (11.x - 12.x)
    If you wish to install a version with no configuration into a new partition, I would recommend setting
    LiveInstall.MoveConfig = disable
    LiveInstall.SaveConfig = disable
    From 11.5.0, when you select a new Boot Location in the GUI, you have the option to Install Configuration, which copies the latest saved configuration from the current volume into the target volume (if it is the same version or a newer version).
    There are no supported tools that allow migration of a config from a newer version to an older version.
