Difference between Clock and date in F5
Guys,
Can you let me know the exact difference for clock and date in f5. When I check the logs from bash the log time it shows matches to the "date" output. When I check the logs from tmsh the log time matches to "date" output. Is there a way to change the clock timing?
- PeteWhite
Employee
Very confused about what you're asking here - all of those things are taken from the system clock which is controlled by NTP normally or if not then can be set using the date command.
AFAIK, the dates should match whether you are using the
command or thetmsh show sys clock
/date
commands from bashclockThe LTM logs should reflect the time zone too.
Do you have a timezone configured?
tmsh list sys ntp timezoneThe output should be something like this
sys ntp { timezone US/Eastern }
