Davide_Podda_21's avatar
Davide_Podda_21
10 years ago
diameter and ssl
Hi all,
I have a question about diameter balancing with SSL client profile.
I'm noticing that with diameter profile I'm not able to use SSL::disable and SSL::enable in irules.
I tried this configuration for testing
when CLIENT_ACCEPTED {
  SSL::disable
In http profile (I tried it just for test) it works well.
In diameter profile it doesn't work.
So my question is: Can I use SSL::enable/disable in diameter profile?
I need this because my diameter client establish a no TLS connection with CER/CEA exchange and only after this exchange start the TLS handshake in the same session. So I'm looking if it's possible use irules to support this.
Using a full TLS session or full no-TLS session everything is ok.
Thanks,
Davide
