Al_Faller_1969's avatar
Al_Faller_1969
May 09, 2006
Determining Failover State with Perl & iControl
Hi All -
I'm new to iControl, but old to perl. I'm attempting to determine the active/passive state of my F5 BigIPs using the SDK and perl. I think I'm on the right track, but I'm not getting any data back from the BigIP. I basically hacked apart one of the samples and came up with the attached code. Please note that I am able to run the sample code. Any idea why I get nothing?
Here is what I get when I run it:
$ ./SystemState.pl bigip 443 admin adminpw
System State
Thanks in advance!
  • You left a bit of the old code in the response parsing. The get_failover_state() method returns an enum containing the current failover state. This should work for you:
    sub getSystemState()
      print "==========================================================\n";
      print "System State\n";
      print "------------------\n";
      $soapResponse = $soap->get_failover_state();
      if ( $soapResponse->fault )
        print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
      else
        $FailoverState = $soapResponse->result;
        print "State: $FailoverState\n";
    -Joe
