Daniel_21056's avatar
Daniel_21056
Dec 22, 2011
Design Help
I may not be wording my search but wasn't able to find a thread for this.
I am on a MPLS network with multiple locations. I want to create a VIP on the LTM and use members in the pool that are geographically separated. Is this possible to do with the LTM?
  • I want to create a VIP on the LTM and use members in the pool that are geographically separated. Is this possible to do with the LTM?if pool member is reachable by ltm, it should be fine. you may have to use snat to force return traffic back to ltm before goinig to client.
