mamat_132868's avatar
mamat_132868
Dec 25, 2013
Deployment guide for BIG-IP ASM 1600 and 3600
is there any guide for below deployment? - BIG-IP ASM 1600 - BIG-IP ASM 3600 how is the resource provisioning for both device?
  • What you can do is a cluster.
    Since 11.3 you can define heterogeneous cluster.
    I suggest you to define LTM and ASM on the same configuration, you will have the best performance/security combo with that.
  • so i should configure LTM and ASM the same configuration?where should i deploy both device..is it LTM first or ASM first after the CORE switch.
  • Not the same configuration but on the same platform.
    As it's on the same platform, you won't have to choose what's first.
    And internally, it's LTM first on TMOS infrastructure.
