Bilash_316418's avatar
Bilash_316418
Apr 05, 2017
Defference between 5050s & 5250v
Hi
please tell me the differences between f5 BIG-IP 5250v and 5050v chassis. How should I decide between them? Is this model are in same chassis? The chassis of a 5250v is always of a 5050s and additional features of 5250v as compared to 5050s are unlocked via a soft license upgrade ?
Regards Bilash
  • nathe's avatar
    nathe
    Bilash, yes same chassis but performance upgrade by buying a license to upgrade from 5050s to 5250v.
    Hope this helps,
    N
  • Dear,
    Once you activate the license you can always check the product information by going to the below website and entering the serial numbers.
    https://secure.f5.com/validate/validate.jsp
    You will receive an email with exact product information and also the warranty info including any service contracts you purchased.
    Regards,
    Mohammed Shiraz
