Brian_69413's avatar
Brian_69413
Jun 14, 2012
Default pool in a switch statement
We have a Virtual Server that is assigned a default pool and also an iRule that applies a different pool given a certain path. We believe this was working fine as an if statement, but was recently changed to a switch statement. We started to receive reports that traffic not matching one of the cases(I.e. hitting the default). We're still ending up at the secondary pool. A pool statement in the default case fixed this, but was wondering why this would be necessary. Also, is it different from an IF statement, or was it just a coincidence?
I assumed that these non-matching cases would look to the VIP config for pool info.
  • hoolio's avatar
    hoolio
    Hi Brian,
    Did you have an else clause in the if statement? If so, you were assigning a pool in all cases in the iRule. If you didn't have an else clause, I'd guess it was just coincidence that you noticed the issue after changing to a switch statement.
    I think it's most intuitive if you use an iRule to assign a pool in some cases to do it in all cases. If you want to reference the VS default pool, you can save the name in CLIENT_ACCEPTED:
    when CLIENT_ACCEPTED {
       set default_pool [LB::server pool]
       switch -glob [HTTP::path] {
          "/app1*" {
             pool pool_app1
          "/app2*" {
             pool pool_app2
          default {
             pool $default_pool
    Or if you want to avoid specifying the pool in each iRule condition, you could add a OneConnect profile to the virtual server. If you're using SNAT, you can use the default OneConnect profile with a /0 source mask. Else, create a custom /32 source mask OneConnect profile and add that to the virtual server.
    Aaron
  • Thanks, that is helpful info. The reason I was down this path is because one case has a redirect, one just changes the path and the other assigns a new pool. I will take your advice and modify all cases to include the default pool.
