cawong23_136311's avatar
cawong23_136311
Nov 28, 2016
Default monitor on node (node list shows unknown) caused pool monitor down.
Hi all,
I found that the node can set default monitor for nodes, however once i set it, it will cause the pool monitor down... I removed the default monitor and then the pool becomes normal again.
Could you please advise?
Thanks in advance!
  • The default monitor associated with nodes are ICMP. And the pools will also have some monitor associated with it, usually if the services is running - the member will be marked up and inturn marking the pool available.
    Removing the default monitor should not cause any impact on the pool, because pool also has a monitor configured in it.
    Can you please share your config, showing what monitor is configured in pool.
  • What is the status of the node when you enable the default node monitor??
    The member status in a pool is a combination of the pool monitor and the node monitor. Both need to be up to mark a pool member as up.
    In older software versions the default node monitor was set to icmp, newer versions don't have a default node monitor.
    My advice would be to not use a monitor on the node's.
    Cheers,
    Kees
