Default global parameters in F5 LTM and AFM
Hi F5 Community,
We would to like ask if there's a way in F5 thru TMSH command wherein we check or show all the default parameters or global variables set in F5?
Which we will export to a notepad or excel so that we can made a comparison from one existing system to a new one.
Thank you in advance who will be able to help us in our inquiry.
it's "tmsh list all-properties"
for comparison purpose, simply generate the qkview then do the comparison in https://ihealth.f5.com/
Hello Tony, usually the config-file will only display the non-standard entries when called with TMSH "list" command, but you can just input the "all-properties" keyword to show every parameter.
example: tmsh list ltm virtual <name> all-properties
- T0nyP
Cirrus
Hi CA_Valli, thank you...is there a way to check as a whole appliance type or LTM module not only on the VS level?
I saw this URL https://clouddocs.f5.com/cli/tmsh-reference/v13/modules/cli/cli_global-settings.html
May I ask what is the correct command of tmsh for the list and all properties?
