bluestar007_339's avatar
bluestar007_339
Dec 05, 2017
default cipher string
The below string is valid ? DEFAULT:!SSLv2:!EXPORT:!DHE+AES-GCM:!DHE+AES:!DHE+3DES:ECDHE+AES-GCM:ECDHE+AES:RSA+AES-GCM:RSA+AES:ECDHE+3DES:RSA+3DES:-MD5:-SSLv3:-RC4
  • Are you looking for SSL-Labs rating? @Kai has already publish article to get Qualys SSL-Labs rating.
    Please go through it. Link
    • bluestar007_339's avatar
      bluestar007_339
      Hi, yea i got the string from there only . My question I can simply add the string in the cipher text field
    • Samir_Jha_52506's avatar
      Samir_Jha_52506
      Icon for Noctilucent rankNoctilucent
      Yes. Just add the below cipher in cipher text field in stage application ssl profile & validate it, Then replicate to prod application profile.
