data group management portal
Hi all,
anyone has an irule that displays a web page that can manage (add/remove/modify values) a certain data group ,
it is needed to allow specific administrators to modify only that data group
Thanks Player
- The_Bhattman
I believe the most efficient way to do this if via iControl
Here is the codeshare for iControl (containing examples with actual cod to make it work)
https://devcentral.f5.com/wiki/iControl.CodeShare.ashx
- player_72606
i'm looking for a solution on the bigip without using icontrol, i heard about the ability to create a web page using irule, but creating the UI for updating only specific Data Group is a bit more complex
- The_Bhattman
There is an iRule in the codeshare that demonstrates creating a webpage using iRule and storing some user inputs using the STATS profile.
https://devcentral.f5.com/wiki/iRules.LTMMaintenanceWindow.ashx
However, manipulating a datagroup is a bit trickier.
Here is a posting talking about some methods to get that piece to work
https://devcentral.f5.com/questions/modifying-external-datagroup-within-an-irule
