Chandru_14793's avatar
Chandru_14793
Feb 25, 2011
Custom UDP Monitor
I need to create a custom UDP monitor, which can Send an input string and waits for a particular output string.
I went to LocalTraffic->Monitors>create newMonitor>UDP
Under Advanced section, I see Send String under it. I dont see Receive string which can verify the output
how can I get the Receive String populated
We have an server pool which responds to udp queries (Not DNS or NTP). We need to verify the output and remove the server from the pool based on reply strings
  • hoolio's avatar
    hoolio
    Which LTM version are you working with? On 10.2.1, there is a send and receive string section for a UDP monitor.
    Aaron
  • hoolio's avatar
    hoolio
    It looks like this was added in 10.2.0 per CR131196. I guess the original logic is that if LTM doesn't get an ICMP port unreachable message, the service is considered to be up. If you want to check the reply you could either use an external monitor with netcat to send a request or upgrade to 10.2.0 or higher (ideally 10.2.1).
    See SOL6143 for a description of the pre-10.2.0 UDP / ICMP monitor behavior:
    sol6143: UDP health monitor operation
    http://support.f5.com/kb/en-us/solutions/public/6000/100/sol6143.html
    Aaron
