Alain_2938
Jul 21, 2014Custom http Regex monitor Syntax
I need to create an http regex monitor for the following criteria:
SEND: "GET /example/monitor/monitor.do?parameter=DB_USER HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n" RECEIVE: regex “^0$
How can I put this together using the BigPipe command?
- Kevin_Stewart
Employee
Your receive string regex basically says "match if the string only contains a 0", which is correctly formatted according to this:
http://support.f5.com/kb/en-us/solutions/public/5000/900/sol5917.html
Not certain anymore how to do this with bigpipe, but here's what that might look like with tmsh:
tmsh create ltm monitor http dc-test-monitor defaults-from http send "GET /example/monitor/monitor.do\?parameter=DB_USER HTTP/1.1\r\nHost: localhost\r\nConnection: close\r\n\r\n" recv "^0$"
