Custom http monitor and http error 500
Hi i am trying to fix a custom monitor that is for a load balanced https offloaded webservice , the service has a status api request that is called using /cpqserver/api/status using http. That then returns the following information:-
1.5.0.51 Active True localhost net.tcp://localhost:5000/Tribold/PPM/Internal/CpqDataService 5000 False 2014-10-19T17:30:10 True True
The problem is i would like to use one monitor and cant seem to get a command syntax that works, for both nodes. The following http request works for one node but i would like to able to have a command that works oavsett node.
GET /cpqserver/api/status/ HTTP/1.1\r\nHost: hostname.domain.com\r\nConnection: Close\r\n\r\n
IS there away to do this without putting in the nhost ?
/Regards Craig
- Hannes_Rapp
You can certainly do that without specifying the HTTP "Host" parameter. However, by doing that, the health-check sent by F5 might be served by a different vHost in end-server. To put it short, it depends on vHost config in end-servers and how the listeners are configured.
You can emulate the health-check from F5 with cURL or WGET. This should give you a hint whether you can get this health-check working without touching the vHost configs in end-servers.
Test with Host header specified:
curl -vH "Host:www.mydomain.com" http://end-server-ip:port/cpqserver/api/statusTest without Host header:
curl -v http://end-server-ip:port/cpqserver/api/status
