Custom Http and Https health check
Im trying to create a custom health check In the Send string I have fqdn/fmi/xml/fmresultset.xml?-db=PRM&-lay=XML_LoandBalancer_Prefs&-findall&-max=1
For the receive string I have Yes
When I copy this url into my browser I see the yes in the data field Yes
- Kevin_Stewart
Employee
What is your question? - DTak_116266
The node wont come up. Its being marked down.
- Kevin_Stewart
Employee
Your best first start will probably be to watch the monitor traffic between the BIG-IP and server. If you can temporarily turn off SSL at the server and just to HTTP port 80, you won't have to mess with decrypting the SSL. Otherwise you'd need to run ssldump to see the traffic. What you're looking for is to see what the monitor request looks like and what the server's response looks like. You could spend a lot of time troubleshooting a monitor config to find out later that the server wasn't sending what you thought it should.
