curl test output
Hi
I have to configure below https health send string with receive string as 200 OK.
GET /r/test HTTP/1.1\r\nHost: abc.xyz.co.in\r\nConnection: Close\r\n\r\n
Below is the curl test output. Here 172.16.1.2 is the one of pool member IPs where this health monitor will be applied.
curl -v http://172.16.1.2:443/abc.xyz.co.in * About to connect() to 172.28.239.26 port 443 (0) * Trying 172.16.1.2... connected * Connected to 172.16.1.2 (172.16.1.2) port 443 (0)
GET /abc.xyz.co.in HTTP/1.1 User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/1.0.1l zlib/1.2.3 libidn/0.6.5 Host: 172.16.1.2:443 Accept: /
Could someone advise me please what is happening here from seeing the curl test output. Do I need to ask server team to configure 200 ok as receive string on server side or else what should be configured on the server side . Why we are not getting any response from server side on running curl test...
- nathe
Cirrocumulus
It looks like you are trying to curl to http, not https, also there may be certificate errors. Does this work better for you?
curl -vk https://172.16.1.2:443/abc.xyz.co.inThe k switch ignores certificate issues.
N
