Blue_whale's avatar
Blue_whale
Feb 07, 2022
curl command not giving full output when used in Ansible f5 module .
Hi Experts ,
Below comand is not giving the complete output when we run this command from f5 Ansible Module .. Anyone knowns any workaround ?
curl -vk https://example.com
  • Can you please elaborate which module and parameters you are using (e.g. by showing the playbook task)?
    Maybe the ansible version would help as well.
    • Blue_whale's avatar
      Blue_whale
      We tried beow 2 scripts but we are getting the output but with error at the end ...output does not completes.
      - name: Run curl command
      raw: curl -vvvk "https://{{VIP_IP[1]}}:{{VIP_PORT}}"
      register: curl_result
      failed_when: '"Connected" not in curl_result.stderr'
      ignore_errors: yes
      or
      shell: curl -vvvk "https://{{VIP_IP[1]}}:{{VIP_PORT}}"
      ignore_errors: yes
      OUTPUT :
      * Rebuilt URL to: https://192.168.12.135:443/
      * Trying 192.168.12.135...
      * TCP_NODELAY set
      % Total % Received % Xferd Average Speed Time Time Time Current
      Dload Upload Total Spent Left Speed
      0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Connected to 192.168.12.135 (192.168.12.135) port 443 (#0)
      * ALPN, offering h2
      * ALPN, offering http/1.1
      * successfully set certificate verify locations:
      * CAfile: /etc/pki/tls/certs/ca-bundle.crt
      CApath: none
      } [5 bytes data]
      * TLSv1.3 (OUT), TLS handshake, Client hello (1):
      } [512 bytes data]
      * TLSv1.3 (IN), TLS handshake, Server hello (2):
      { [81 bytes data]
      * TLSv1.2 (IN), TLS handshake, Certificate (11):
      { [956 bytes data]
      * TLSv1.2 (IN), TLS handshake, Server key exchange (12):
      { [527 bytes data]
      * TLSv1.2 (OUT), TLS alert, handshake failure (552):
      } [2 bytes data]
      * error:141A318A:SSL routines:tls_process_ske_dhe:dh key too small
      * Closing connection 0
      curl: (35) error:141A318A:SSL routines:tls_process_ske_dhe:dh key too small
      • chrros95's avatar
        chrros95
        Icon for Cirrus rankCirrus
        To me it looks like you're not using an f5-ansible module but the built-in ansible.builtin.raw module. Furthermore the output looks more or less complete as the error is the last thing that curl will print on failure.
        You can try to use curls --ciphers option to avoid this error (e.g. curl -vvvk --ciphers ' ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:!DH:@STRENGTH' "https://{{VIP_IP[1]}}:{{VIP_PORT}}" ).
        As well, you can consider to use the f5networks.f5_modules.bigip_command as it is F5s way to execute commands.
