Anthony
Aug 29, 2013crontab not being executed
Hi all, I have followed the steps on the following link to set up a crontab entry for nightly UCS backups. http://support.f5.com/kb/en-us/solutions/public/13000/400/sol13418.html
We have 3 HA pairs of LTMs and 2 pairs are running fine. However, the same crontab entries just don't run on one of the pairs.
Have I missed something in the configuration to enable the crontab?
Thanks Ant
- have you checked the usual log files for errors? have you tried to execute the command yourself to see if it succeeds? are all LTMs running the same TMOS version?
- Anthony
How do I check the TMOS version?
The command executes just fine when run from the command line. tmsh save /sys ucs /var/local/ucs/$(date '+%y%m%d')
