Create net routing bgp issue, RCI for BGP and BFD (ZebOS to tmsh ROUTING)
Hello, I am trying to migrate a BGP configuration from ZebOS to tmsh tmsh to test the new functionality of 13.1.0 (Routing Configuration Integration (RCI) for BGP and BFD).
I activate TMOS ROUTING by: tmsh modify sys db tmrouted.tmos.routing value enable.
when I try to configure the TMOS BGP by: create net routing bgp TEST local-as 65540,
I have this error message :
[api-status-warning] net / routing / bgp is early_access 01071c3f: 3: Can not mix routing-protocol Legacy and TMOS mode for route-domain (/ Common / 0).
Any idea please ???
- Andy_McGrath
Cumulonimbus
Are you trying to create your BGP routing directly from
?tmshI am sure this is only supported from version 14.0, in 13.1.0 you will need to use ZebOS (see Manual: BIG-IP Advanced Routing Border Gateway Protocol CLI Reference)
- Peter_Mills_697Historic F5 Account
Since these approaches to provisioning are mutually exclusive, do not enable any routing protocol under Network >> Route Domains “Dynamic Routing Protocols”
