Claret_Carvalho's avatar
Claret_Carvalho
Sep 08, 2009
CPU reporting of F5 devices
Has anyone successfully managed to get SevOne tool (www.sevone.com) to do performance reporting of LTM/GTM devices, specifically on CPU and Memory utilization? Just a general question, does anyone what snmp oid's the RRDtool uses and how they derive the utilization figure to generate graphs locally on the device? I have read the snmp configuration guides but it is still not clear.
Thanks,
Claret
  • hoolio's avatar
    hoolio
    Hi Claret,
    Citizen_elah has done some very helpful work in this area with Perl / Cacti. Here is a post where he added an example of using SNMP to track CPU usage:
    cpu monitoring
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=32&tpage=1&view=topic&postid=1623716242
    Aaron
  • Pre-v.10, you have to do all manual calculations. New in v10 is a ratio oid for 5 second, 1 minute, & 5 minute cpu usage, per processor and globally. These are:
    (indexed, there is a value for each processor present)
    sysMultiHostCpuUsageRatio5s
    sysMultiHostCpuUsageRatio1m
    sysMultiHostCpuUsageRatio5m
    (singular value)
    sysGlobalHostCpuUsageRatio5s
    sysGlobalHostCpuUsageRatio1m
    sysGlobalHostCpuUsageRatio5m
    I'll have a tech tip up later this week complete with a cacti template for multi-processor systems, but here's the perl script for displaying CPU goodies to the console (you'll need the Net-SNMP perl module)
     !/usr/bin/perl -w
      This code is not supported by F5 Network and is offered under the GNU General Public License.  Use at your own risk.
     use strict;
     use Net::SNMP qw(:snmp);
     my ($host, $snmp_comm);
     $host = $ARGV[0];
     $snmp_comm = $ARGV[1];
     chomp ($host , $snmp_comm);
     my $cpuID        = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.3.1.48";
     my $cpuIndex     = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.2.1.48";
     my $cpuUsageRatio5s = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.19.1.48.";
     my $cpuUsageRatio1m = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.27.1.48.";
     my $cpuUsageRatio5m = ".1.3.6.1.4.1.3375.2.1.7.5.2.1.35.1.48.";
     my $gcpuUsageRatio5s = ".1.3.6.1.4.1.3375.2.1.1.2.20.21.0";
     my $gcpuUsageRatio1m = ".1.3.6.1.4.1.3375.2.1.1.2.20.29.0";
     my $gcpuUsageRatio5m = ".1.3.6.1.4.1.3375.2.1.1.2.20.37.0";
     my ($session, $error) = Net::SNMP->session(
     -hostname       => $host,
     -community      => $snmp_comm,
     -port           => 161,
     -version        => 'snmpv2c',
     -nonblocking    => 0
     if (!defined $session) {
     print "Received no SNMP response from $host\n";
     print STDERR "Error: $error\n";
     exit -1;
     my $allCPU = $session->get_table ( -baseoid => $cpuIndex );
     my %cpu_table = %{$allCPU};
     my $x = 0;
     print "\n\nCPU Utilization:\t5s\t1m\t5m\n\n";
     foreach my $key (sort keys %cpu_table) {
     my @oid_index = split(/\./, $key);
     my $ltm_cpu5s = $cpuUsageRatio5s . $oid_index[-1];
     my $ltm_cpu1m = $cpuUsageRatio1m . $oid_index[-1];
     my $ltm_cpu5m = $cpuUsageRatio5m . $oid_index[-1];
     my $oid_ratios = $session->get_request(
     -varbindlist =>
     [$ltm_cpu5s, $ltm_cpu1m, $ltm_cpu5m] );
     print "\tCPU$x\t\t$oid_ratios->{$ltm_cpu5s}\t$oid_ratios->{$ltm_cpu1m}\t$oid_ratios->{$ltm_cpu5m}\n";
     $x++;
     my $oid_gratios = $session->get_request(
     -varbindlist =>
     [$gcpuUsageRatio5s, $gcpuUsageRatio1m, $gcpuUsageRatio5m] );
     print "\tGlobal\t\t$oid_gratios->{$gcpuUsageRatio5s}\t$oid_gratios->{$gcpuUsageRatio1m}\t$oid_gratios->{$gcpuUsageRatio5m}\n\n\n";
    Output for my 3600:
     vadmin@vadmin:/tmp$ ./ltmcpu.pl 10.10.20.5 public
     CPU Utilization:        5s      1m      5m
             CPU0            3       3       3
             CPU1            2       3       3
             Global          2       3       3
  • BTW, if these intervals (5s/1m/5s) don't work for you, you can still use the other oids and do the calculations manually, as you have to do for the TMM utilization as well. They are:
    For CPUn:
    sysMultiHostCpuUser
    sysMultiHostCpuNice
    sysMultiHostCpuSystem
    sysMultiHostCpuIdle
    sysMultiHostCpuIrq
    sysMultiHostCpuSoftirq
    sysMultiHostCpuIowait
    For Global:
    sysGlobalHostCpuUser
    sysGlobalHostCpuNice
    sysGlobalHostCpuSystem
    sysGlobalHostCpuIdle
    sysGlobalHostCpuIrq
    sysGlobalHostCpuSoftirq
    sysGlobalHostCpuIowait
    Calculation for both CPUn & Global is:
    ((dUser + dNice + dSystem)/(dUser + dNice + dIdle + dSystem + dIrq + dSoftirq + dIowait))*100
    For TMM:
    sysStatTmTotalCycles
    sysStatTmIdleCycles
    sysStatTmSleepCycles
    Calculation is:
    ((deltaTotal - (deltaIdle + deltaSleep)) / deltaTotal)*100
    HTH...Jason
