ConnectionLimit Not Found
I have been facing this issue:
I am using below URL (for iControl REST) to obtain Connection Limit for a member (or web server) under a specific Partition and Pool. This works just fine when I select partition as
Common but fails (with error: 404 Not Found) when I select a specific partition.
f5UrlConnectionLimit = "https://F5HostName.com/mgmt/tm/ltm/pool/~<partition>~<pool>/members/~<partition> ~ <member>;
Note: Tags marked with <> are to be replaced with actual values
Does anyone have a solution why is it working fine only for
Common partition and failing for others?
- Dario_Garrido
Noctilucent
The best way to troubleshoot this is to use global searches and check the selfLink fields to figure out the right syntax
For example, run some of these commands and check the output.
curl -sk -u admin:admin https://F5HostName.com/mgmt/tm/ltm/pool/ | json-format curl -sk -u admin:admin https://F5HostName.com/mgmt/tm/ltm/pool/~<partition>~<poolname>/members/ | json-formatYou would see the right syntax of each pool member (with the correct partition) in the selfLink.
"selfLink": "https://localhost/mgmt/tm/ltm/pool/testpool/members/~Common~192.168.101.11:8000?ver=11.5.1"REF - https://devcentral.f5.com/s/articles/icontrol-rest-working-with-pool-members
KR,
Dario.
