luoye's avatar
luoye
Jul 05, 2017
connection reuse
Hi,everyone:
There is a demand that we need F5 keep the connection with server after client remove connection.When a new connection come in,it reuse the free connection.And I want the connection less than 100.Of course,it sounds like oneconnection feature,but oneconnection doesn't work expectedly.And the number of connecton can't be controled.So,do you have any other idea? Thanks!
  • luoye's avatar
    luoye
    And the 100 connection should be keeped forever to ensure the snat port isn't changed.
