Connection Re-use for Non-HTTP Protocols
Dear All, Hope you are doing Well, Our scenario is as following: Several clients send their requests (based on MSMQ Protocol) to one Virtual server, But this VS must establish ONLY and ONLY 'Single' connection to our pool member to handle all the clients' requests / responses (there is just ONE Pool member at Server-side). In case of using HTTP traffic, I know that "OneConnect" + "HTTP" profiles would be the answer. But, by considering the fact that "iRule" script is interpreted per packet, is there any solution for our scenario to reusing the Server-side connection for all the clients?
- Simon_Blakely
Employee
Just use OneConnect - you do not have to have an HTTP profile.
K7208: Overview of the OneConnect profile
The OneConnect profile may be used with any TCP protocol, but only when applied to virtual servers that process simple request/response protocols where transaction boundaries are explicitly obvious, such as those in which each request and each response is contained within a single packet.
- stan_piron
Cumulonimbus
Look at tcp::notify / lb:detach / USER_REQUEST event wiki...
There is an example of such configuration in this article
