connection behavior with or without oneconnect
hi ,dear Irule according to test in lba,here is what I found for connection behavior with/without oneconnect all tests have http profile enabled,and source
1:without oneconnect profile after client----vs,vs---backend server connection established,after keep alive timeout is met,backend "fin ack" connection with F5,then VS "fin ack " with client.
2:with oneconnect profile after client----vs,vs---backend server connection established,after keep alive timeout is met,backend "fin ack" connection with F5,but VS doesn't send "fin ack " with client.
3:it seems client ,such as IE chrome doesn't hornor keep-alive:timeout in response from backend server even ,after the timeout value,it can still reuse the client side keep alive connection
- Hannes_Rapp_162
Nacreous
What is your question? You can read about configuring Oneconnect here: https://support.f5.com/kb/en-us/solutions/public/7000/200/sol7208.html
- Robert_47833
Altostratus
I want to confirm whether my words matches the expected behavior? - Hannes_Rapp_162
Nacreous
1) yes 2) yes 3) yes. The keep-alive setting as set in a clientside profile supersedes server responses. - Robert_47833
Altostratus
thanks for your confirmation
- Hannes_Rapp
- Robert_47833
Altostratus
Altostratus
- dragonflymr
Just wonder do you mean Keep Alive Interval or Idle Timeout from TCP profile? I guess that for server side connections with OneConnect applied what is used to end connection are settings from OneConnect profile (Maximum Age, Maximum Reuse) not from TCP profile - but may be wrong, I am not really sure what Idle Timeout Override (in OneConnect) setting is changing in this equation. Or maybe it's like that: 1. Maximum Age (OC profile) specifies how long server side connection can be used, after specified number of seconds connection is closed if it's Idle Timeout in TCP profile was not exceeded 2. If Maximum Age did not pass but Idle Timeout in TCP connection expired then server connection is closed not honoring Maximum Age setting 3. When it's necessary to have different Idle Timeout for server side (using OC) for setting in TCP profile (and used in this case for client side connections) then it can be changed using Idle Timeout Override in OC profile Is above makes sense? Piotr - Robert_47833
Altostratus
thanks for your reply I want to know the keep alive:timeout sent from backend server and its related behavior
