configuring Pools on Management port
I have a back end server running on port 7580, but my user wants my pool to be configured on port 11000, which is his management port. He wants all the http/https traffic for the server to listen on port 11000. so i have configured the VIP which is shown below
destination a.b.c.d:https ip-protocol tcp mask 255.255.255.255 pool PL_Prod_test profiles { SSL_test { context serverside } SSL_Test_client { context clientside } http { } tcp-lan-optimized { context serverside } tcp-wan-optimized { tmsh context clientside } } source 0.0.0.0/0 source-address-translation { type automap } vs-index 884 and pool as
members { ddibc02:irisa { address h.g.f.e session monitor-enabled state up } } monitor gateway_icmp }
when i am assigning tcp monitor or custom tcp monitor with port 7580, it is marking down. only gateway-icmp is working. but with gateway icmp whrn i try to access the page it is not showing up. Am i configuring anything wrong? Please help me finding the issue.
Thanks,
sekhar
- StephanManthey
Nacreous
Hi sekhar,
your poolmembers are configured to listen on port 11,000:grep -i 'irisa' /etc/services irisa 11000/tcp IRISA irisa 11000/udp IRISAIf the service works fine on this port, you can use a plain tcp or tcp_half_open monitor to health check.
The monitor will automatically pick the configured port of the pool member to connect to. Thanks, Stephan
