Configuring an interface with a tagged vlan and assigning an IP to it
So i just configured a tagged vlan over an interface on my Big IP in the production environment and assigned an IP address to it. Its supposed to be a simple point to point connectivity. The IPs are in the same /29 subnets however there is no ping
Here are the steps I followed
1- Create Vlan Client --> vlan id 1000 --> tagged interface 1/2.2
2- Assigned a physical self IP against it 10.18.231.212/29
3- Assigned a floating IP for vlan: Client 10.18.231.211/29
4- Router IP configured in the same vlan ID is 10.18.231.209/29
I suspect there is a cabling issue ? Any comments. The config is pretty straight forward.
- Cheeky_168406
The design is like below
VLAN Name IP Network VLAN ID IP Address Hostname Interface Ingress 10.18.231.208/29 1000 10.18.231.209 EFS1 1/4 /Client 10.18.231.210 EFS2 1/4 10.18.231.211 F5_Floating 10.18.231.212 F5A_Physical 1/2.2 10.18.231.213 F5B_Physical 1/2.2 - shaggy_121467
Cumulonimbus
Is the remote interface a trunk port with vlan 1000? You might try making the interface untagged in vlan 1000 to see if it makes a difference.
- Cheeky_168406
Hi yes its a trunk port as we are configuring our F5 ports for multiple vlans. However, the very first vlan is not working. There is another vlan assigned on the same port (FYI)
- shaggy
- Cheeky_168406
- shaggy_121467
Cumulonimbus
When you ping the F5 self-IP from the router and vice versa, do you see anything populated in the ARP tables for the involved IP addresses?
- Cheeky_168406
nope I dont see any arp entries for the new vlan ! The interface is up - shaggy_121467
Cumulonimbus
The configuration on the F5-side looks correct. If there's another functional VLAN tagged on the same interface, then it sounds like an interface or VLAN 1000 configuration issue on the remote end or a cabling issue.
- shaggy
- Cheeky_168406
- What_Lies_Bene1
So the switch has the VLAN configured and trunked/tagged on the relevant interfaces connecting the F5s. No pruning taking place?
- Cheeky_168406
so that means media is communicating[root@XXXXX:/S2-green-P:Active] config tmsh sh net interface 1/2.2 all-properties Net::Interface Name Status Bits Bits Pkts Pkts Mcast Mcast Errs Errs Drops Drops Colli Media Flow Trunk Aggreg In Out In Out In Out In Out In Out sions Ctrl ------------------------------------------------------------------------------------------------------------------------------ 1/2.2 up 69.8M 211.0K 121.0K 355 121.0K 355 0 0 20.1K 0 0 10000SR-FD tx-rx none detached - Cheeky_168406
so i figured that the ARP is not getting responded
config tcpdump -ni Clients_3:nnn -s0 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on Clients_3:nnn, link-type EN10MB (Ethernet), capture size 65535 bytes 20:20:37.256596 arp who-has 10.18.231.209 tell 10.18.231.212 out slot2/tmm0 lis= flowtype=0 flowid=0 peerid=0 conflags=0 inslot=0 inport=0 haunit=0 peerremote=00000000:00000000:00000000:00000000 peerlocal=00000000:00000000:00000000:00000000 remoteport=0 localport=0 proto=0 vlan=0 20:20:37.256600 arp who-has 10.18.231.209 tell 10.18.231.212 out slot2/tmm0 lis= flowtype=0 flowid=0 peerid=0 conflags=0 inslot=0 inport=0 haunit=0 peerremote=00000000:00000000:00000000:00000000 peerlocal=00000000:00000000:00000000:00000000 remoteport=0 localport=0 proto=0 vlan=0 - Cheeky_168406
another question here is that why the ARP message below shows the vlan=0
- shaggy
try tcpdump -nei http://support.f5.com/kb/en-us/solutions/public/7000/200/sol7227.html
- Cheeky_168406
so in the end it appears the guys at the router end were configuring wrong IPs against the wrong vlans!
