common LDAP monitor DEBUG behavior
Dear all,
I need clarification for the common LDAP Monitor provided by Big-F5. The setup is validated and configured well, also works fine, reason to dig into this is to exclude the Big-F5 as possible problem source in a problem where the appliances are in the chain of devices.
The setup is as follows:
Client (EL5/EL6) sssd LDAP -> Load Balancer Big-F5 -> LDAP Server (EL6)
the monitor used is configured as follows (I changed the values in here for the post):
Parent: LDAP
base: dc=example,dc=com
filter: (&(objectClass=domain)(dc=example))
mandatoryattrs: yes
username: cn=monitorUser
password: changeme
security: ssl
as mentioned before, the checks work fine and the Appliance acknowledges all Nodes as up and running. if I turn on debugging in the check I can see the content in /var/log/.log like
********** Debugging session beginning at: Wed Aug 7 08:00:03 2013
Arguments 1-2:
::ffff:172.27.48.40
636
Environment variables:
BASE=dc=example,dc=com
CHASE_REFERRALS=yes
DEBUG=yes
FILTER=(&(objectClass=domain)(dc=unix))
MANDATORYATTRS=yes
MON_TMPL_NAME=/Common/Company_ldap_ssl_monitor
NODE_IP=::ffff:172.27.48.40
NODE_PORT=636
PASSWORD=changeme
SECURITY=ssl
USERNAME=cn=monitorUser
Host URL: ldaps://[::ffff:172.27.48.40]:636
Up: 1 entries found.
which looks fine too, but the checks following this one (was the first entry after enabling debug) don't show the last Line "Up: 1 entries found."
********** Debugging session beginning at: Wed Aug 7 08:00:13 2013
Arguments 1-2:
::ffff:172.27.48.40
636
CHASE_REFERRALS=yes
DEBUG=yes
MANDATORYATTRS=yes
MON_TMPL_NAME=/Common/CTBT_ldap_ssl_monitor
NODE_PORT=636
PASSWORD=changeme
SECURITY=ssl
********** Debugging session beginning at: Wed Aug 7 08:00:23 2013
is this a well known and wanted behavior or should it read "Up: 1 entries found" all the time ?
thanks for you help ...
kind regards
Michael Lang
- nitass
Employee
is this a well known and wanted behavior or should it read "Up: 1 entries found" all the time ?i checked past support case and found it does not happen all the time but monitor is working properly.
