Closing down outside management
Is there a way to block connections to the outside address of the F5 so all management connections would be done via the management IP?
- R_Eastman_13667Historic F5 Account
Create an internal VLAN that is only accessible within your organization, configure the Management Port with an IP address in this VLAN. Platform >> Configuration >> Management Port.
- sundogbrew
Altocumulus
I have the management NIC on a private network that can only be accessed by VPN, but what do you do about the outside address? Can you just remove it?
- shaggy
each self-IP address has "port lockdown" which allows you to "allow none" in regards to connections directly to the self-IP
