Clone traffic sent on port 0, need actual port
I tried the clone pool feature within the VIP settings but there's no traffic being sent to the clone server (not layer 2 adjacent). The iRule below works but the traffic is sent to the clone pool on x.x.x.x.0 instead of x.x.x.x.8897. The VIP, the assigned pool and the clone pool are all wildcard. The port is correct when sent to the assigned pool but it's 0 when sent to the clone pool. Customer needs the actual port on the clone pool. Any ideas?
PS. The customer uses 13 ports and counting. Would rather not create 13 VIPs, pools and iRules.
when CLIENT_ACCEPTED {
# Open a new HSL connection if one is not available
set hsl [HSL::open -proto TCP -pool mooglamacc-clone-0-pl]
#log local0. "[IP::client_addr]:[TCP::client_port]: New hsl: $hsl"
# Insert an XFF header if one is not inserted already
# So the client IP can be tracked for the duplicated traffic
HTTP::header insert X-Forwarded-For [IP::client_addr]
# Check for POST requests
if {[HTTP::method] eq "POST"}{
# Check for Content-Length between 1b and 1Mb
if { [HTTP::header Content-Length] >= 1 && [HTTP::header Content-Length] < 1048576 }{
HTTP::collect [HTTP::header Content-Length]
} elseif {[HTTP::header Content-Length] == 0}{
# POST with 0 content-length, so just send the headers
HSL::send $hsl [HTTP::request]
#log local0. "[IP::client_addr]:[TCP::client_port]: Sending [HTTP::request]"
# Request with no payload, so send just the HTTP headers to the clone pool
when HTTP_REQUEST_DATA {
# The parser does not allow HTTP::request in this event, but it works
set request_cmd "HTTP::request"
#log local0. "[IP::client_addr]:[TCP::client_port]: Collected [HTTP::payload length] bytes,\
sending [expr {[string length [eval $request_cmd]] + [HTTP::payload length]}] bytes total"
HSL::send $hsl "[eval $request_cmd][HTTP::payload]"
}3 Replies
- Simon_Blakely
Employee
The problem is that your HSL pool (mooglamacc-clone-0-pl) does not have a port specified - you need to set the port there.
- RiverFish
Altostratus
S, yes it does work if I specify a port for the HSL pool but then I’d have to create 13 vips, 13 irules and 13 HSL pools, one for each port. Was hoping to avoid this.
- Simon_Blakely
Employee
You can't - on an HSL pool, the pool port specifies the port used to send the logging traffic.
It's a different mechanism to a wildcard pool where the port is passed through to the pool member.
You can still use a single VIP and irule, but you will need 13 HSL pools and some decision logic or a datagroup lookup.
Or don't use a HSL pool and use a sideband connection
Advanced iRules: Sideband Connections
