neeeewbie's avatar
Dec 26, 2019
client side disconnect when I reset persistence records?
Hi guys
I need your help
client side disconnect when I delete persistence records?
or just F5 reload balancing to server ?
thank you
  • SWJO's avatar
    SWJO
    I believe you are using source-address affinity persistence.
    The conclusion is as follows.
    there is connection table, so active connection send traffic to same server.
    and then persistence record re-created.
    What is the ultimate purpose of this question?
