jay_gutierrez_4's avatar
jay_gutierrez_4
May 24, 2006
client cert help..
Need help on why Big-IP v4.5 PTF-05 Build 2. The following settings are configured:
PROXY ADVANCED PROPERTIES
Insert certificate: Issuer, Validity, Certificate
Client certificate: Request
Client certificate CA File: CertFile.crt
Client authenticate once: checked
With the following rule specified:
if (http_header("SSLClientCertStatus") contains "OK" and http_header("referer") contains "navy.mil") {
use pool server_pool
else {
redirect to "some other site?appurl=https://%h/%u"
The problem is the site is requesting the client cert fine but is not checking if it is valid or issued by a particular CA. Please help, any document or samples or suggestions would be appreciated.
