edmonaft_351139's avatar
edmonaft_351139
Mar 12, 2018
Clickjacking protection (X-FRAME-OPTIONS) on F5 LTM 12.1.2 HF2 without using iRules
Hi there,
I wonder if is there a setting that controls this within F5 and hopefully without resorting to using irules.
Thank you!
  • nathe's avatar
    nathe
    ASM has a Clickjacking feature but there isn't a core feature in LTM to provide this protection. If you don't want to use an iRule then you can create a Local Traffic Policy, something like this:
    ltm policy /Common/clickjacking {
        controls { response-adaptation }
        requires { http }
        rules {
            x-frame-options_rule {
                actions {
                    0 {
                        http-header
                        response
                        insert
                        name X-Frame-Options
                        value DENY
                ordinal 1
        strategy /Common/first-match
    You may want to enable this on specific URLs.
    Anyway, hope this helps,
    N
