gdoyle's avatar
gdoyle
Feb 20, 2018
CLI command to see load balancing method for all Virtual Servers?
Is there a command in CLI I can use to display the load balancing method for all virtual servers?
Thanks.
  • Load balancing method is a pool setting. You can check it with
     tmsh list ltm pool pool_name load-balancing-mode
    You can run an small script for getting vs-pool relation and then get load balancing method
    ! /bin/bash
    output=$(tmsh list ltm virtual |grep "ltm virtual" | awk -F" " '{ print $3 }')
    for LINE in ${output}; do
      pool=$(tmsh list ltm virtual ${LINE} pool |grep pool |awk -F" " '{ print $2 }')
      if [ $pool != none ]
      then
         echo "Virtual: ${LINE}:"
         tmsh list ltm pool $pool load-balancing-mode
     fi
     done
