class variable pairs possible?
when CLIENT_ACCEPTED {
if {[IP::addr [IP::client_addr] equals "10.64.40.0/24"] } {
node 10.64.40.2
} elseif {[IP::addr [IP::client_addr] equals "10.64.41.0/24"] } {
node 10.64.41.2
etc...
Is it possible to use class with a pair of matched variables? I'm going to have quite a number of these statements and would prefer to keep the irule as small as possible.
Thanks,
-Ken
- hoolio
Hi Ken,
You can use the IP host/subnet = value format (name = value pairing) in 10.1+:class ip_subnets_class { { host 1.1.1.1 { "10.11.0.1" } network 2.2.2.0/24 { "10.10.10.10" } } }
You can then use something like 'set dest [class match -value [IP::client_addr] equals ip_subnets_class]' to do the lookup.
Aaron - Colin_Walker_12Historic F5 AccountSo to re-write your current iRule using hoolio's (sweet and simple) logic above:
when CLIENT_ACCEPTED { set dest [class match -value [IP::client_addr] equals ip_subnets_class] node $dest }
Nice work hoolio, as always.
Colin - yammy1688_99834
Thanks!Didn't work when I defined the class in the irule itself, but worked fine if I defined it in the data group list from the GUI.
- hoolio
Yes, by design, datagroups/classes are separate objects from iRules, so they need to be defined independently.
Glad it's working for you.
Aaron - yammy1688_99834
made a small change to it too, otherwise it broke other stuff since it's being applied to a 0.0.0.0/0.0.0.0 forwarding VS.when CLIENT_ACCEPTED {
if {[class match [IP::client_addr] equals subnets] } {set dest [class match -value [IP::client_addr] equals subnets]node $dest}}
- hoolio
Hi Yammy,
You could try this to eliminate the second class lookup:when CLIENT_ACCEPTED { set dest [class match -value [IP::client_addr] equals subnets] if {$dest ne ""} { node $dest } }
Aaron - Colin_Walker_12Historic F5 AccountGood to know it's working, thanks. And yes, classes are intentionally separate config objects.
Colin
