bluestar007_339's avatar
bluestar007_339
Nov 12, 2017
cipher help
Hi, BIG IP 11.5
I have the following profile
ltm profile client-ssl clientssl {
alert-timeout 10
app-service none
authenticate once
authenticate-depth 9
ca-file none
cache-size 262144
cache-timeout 3600
cert default.crt
cert-extension-includes { basic-constraints subject-alternative-name }
cert-key-chain {
    default {
        cert default.crt
        key default.key
chain none
ciphers DEFAULT
client-cert-ca none
crl-file none
handshake-timeout 10
inherit-certkeychain false
key default.key
mod-ssl-methods disabled
mode enabled
options { dont-insert-empty-fragments }
passphrase none
peer-cert-mode ignore
renegotiate-max-record-delay indefinite
renegotiate-period indefinite
renegotiate-size indefinite
renegotiation enabled
secure-renegotiation require
strict-resume disabled
unclean-shutdown enabled
ltm profile client-ssl test {
app-service none
cert digicert.crt
cert-key-chain {
    digicert {
        cert digicert.crt
        chain gdigicertchain.crt
        key digicert.key
defaults-from clientssl
key digicert.key
passphrase none
I need to change the cipher suite "ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS"
If I change ' CIPHER' in the test profile does it work ? .Or Need to do something else .
app-service none
cert digicert.crt
cert-key-chain {
    digicert {
        cert digicert.crt
        key digicert.key
**ciphers DEFAULT:ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS**
key digicert.key
passphrase none
  • Yup, apply custom cipher configuration to your custom profile, or even better, refer to model below. I've found it's best to leave default vendor profiles untouched at all times. But I also do not want to waste time repeating same custom settings across many app-specific profiles. So I found 3-tiered models work the best. Here's what I do:
    1. clientssl
      (vendor default). Always untouched
    2. clientssl_base
      (defaults-from clientssl). Here I apply my custom configurations to be used across all app-specific profiles. Advantage of having this profile - I only have to define my custom configurations, i.e. preferred cipher suites just once without having to alter vendor defaults.
    3. clientssl_appspecific
      . (defaults-from clientssl_base). This profile has application-specific TLS cert/key pair attached to it, cipher configuration and all other settings are derived from clientssl_base profile.
    • bluestar007_339's avatar
      bluestar007_339
      Hi, Thanks for the reply .
      If the BOX does not support "ECDH+AESGCM" suite ,what is the point adding in profile . How do I make sure that box support ECDH+AESGCM
    • Hannes_Rapp's avatar
      Hannes_Rapp
      ECDH+AESGCM is not a valid keyword for configuration...
      [root@bip-02:Active:Standalone] config  tmm --clientciphers "ECDH+AESGCM"
             ID  SUITE                            BITS PROT    METHOD  CIPHER    MAC     KEYX
      If you really want to match ECDH with AES and GCM, your closest match would be just "AES-GCM" option which would give you all of the following (exact list depends on your BigIP version):
       [root@bip-02:Active:Standalone] config  tmm --clientciphers "AES-GCM"
       0: 49200  ECDHE-RSA-AES256-GCM-SHA384      256  TLS1.2  Native  AES-GCM   SHA384  ECDHE_RSA
       1: 49196  ECDHE-ECDSA-AES256-GCM-SHA384    256  TLS1.2  Native  AES-GCM   SHA384  ECDHE_ECDSA
       2:   163  DHE-DSS-AES256-GCM-SHA384        256  TLS1.2  Native  AES-GCM   SHA384  DHE/DSS
       3:   159  DHE-RSA-AES256-GCM-SHA384        256  TLS1.2  Native  AES-GCM   SHA384  EDH/RSA
       4:   167  ADH-AES256-GCM-SHA384            256  TLS1.2  Native  AES-GCM   SHA384  ADH
       5: 49202  ECDH-RSA-AES256-GCM-SHA384       256  TLS1.2  Native  AES-GCM   SHA384  ECDH_RSA
       6: 49198  ECDH-ECDSA-AES256-GCM-SHA384     256  TLS1.2  Native  AES-GCM   SHA384  ECDH_ECDSA
       7:   157  AES256-GCM-SHA384                256  TLS1.2  Native  AES-GCM   SHA384  RSA
       8: 49199  ECDHE-RSA-AES128-GCM-SHA256      128  TLS1.2  Native  AES-GCM   SHA256  ECDHE_RSA
       9: 49195  ECDHE-ECDSA-AES128-GCM-SHA256    128  TLS1.2  Native  AES-GCM   SHA256  ECDHE_ECDSA
      10:   162  DHE-DSS-AES128-GCM-SHA256        128  TLS1.2  Native  AES-GCM   SHA256  DHE/DSS
      11:   158  DHE-RSA-AES128-GCM-SHA256        128  TLS1.2  Native  AES-GCM   SHA256  EDH/RSA
      12:   166  ADH-AES128-GCM-SHA256            128  TLS1.2  Native  AES-GCM   SHA256  ADH
      13: 49201  ECDH-RSA-AES128-GCM-SHA256       128  TLS1.2  Native  AES-GCM   SHA256  ECDH_RSA
      14: 49197  ECDH-ECDSA-AES128-GCM-SHA256     128  TLS1.2  Native  AES-GCM   SHA256  ECDH_ECDSA
      15:   156  AES128-GCM-SHA256                128  TLS1.2  Native  AES-GCM   SHA256  RSA
      To reduce complexity, I recommend you configure your ciphers as exclusive derivative of ALL or DEFAULT.
      First see what the ALL or DEFAULT is for your BigIP version like this:
      tmm --clientciphers "ALL"
      Then start excluding the junk you do not like with minus (-) signs or exclamation marks (!). The final result will not be as long and bulky as in case of inclusive configuration.
      I.e.
      tmm --clientciphers "ALL:-SHA1"
      See my answer in this thread for cipher ideas for version 11.5.x for PCI compliance https://devcentral.f5.com/questions/pci-cipher-set
      bluestar007_339
      Hi, Now I am getting clear in the subject . Let me ask you why "tmm --clientciphers "ECDH+AESGCM" does it mean BIG ip does not support this ?
      or If i rephrase the question "ECDH+AESGCM" and "AES-GCM" are same ?
      What does this command exactly doing ?
      tmm --clientciphers 'ALL:!EXPORT:!RC4:!DES:!ADH:!EDH:!SSLv3:!TLSv1:!SHA1'
      This will remove !RC4 from the box forever ?
    1. clientssl
    2. clientssl_base
      bluestar007_339
    • Hannes_Rapp_162's avatar
      Hannes_Rapp_162
      I.e.
      See my answer in this thread for cipher ideas for version 11.5.x for PCI compliance https://devcentral.f5.com/s/feed/0D51T00006i7cGzSAI
      bluestar007_339
