Prasath_Varatha
Apr 09, 2016Chrome not able to load URL using only TLS 1.2 with SHA256
We have requirement to use only below list . but the chrome(49v) and firefox (45) was unable to load the URL after having below
ID SUITE BITS PROT METHOD CIPHER MAC KEYX
60 AES128-SHA256 128 TLS1.2 Native AES SHA256 RSA
61 AES256-SHA256 256 TLS1.2 Native AES SHA256 RSA
do they dont support with URL only with TLS 1.2 with sha 256 ? . i could also see the URL works fine in IE 9
- Josiah_39459Historic F5 AccountYou can take a packet capture of the ssl handshake to see exactly which ciphers are being negotiated and selected. Then perhaps cross referencing that with Chrome support forums?
- Krishna_388466
Altostratus
I have the same problem.Are there any settings change needed in chrome.
