Bob_10976's avatar
Bob_10976
Nov 20, 2012
Checking for Ethernet connectivity
We are implementing a new subnet to a network and will need to run them through the LTM. Looking at the GUI I see I have 2 interfaces that show as "down". The LTM is in a remote location so with out being able to phyically look at the front of the device I need to know if the 2 interfaces actually have ethernet cables plugged into them. I did check statistics and there has been no traffic using those interfaces at all.
Is there a command or somewhere in the GUI that will help me determine if there is actually a cable plugged into this, vs having to drive to the location..
Thanks,
Bob
  • On a Viprion running 11.2.1HF1:
    (cfg-sync In Sync)(/S1-green-P:Active)(/Common)(tmos) sh net int 1/1.1
    Net::Interface
    Name Status Bits Bits Pkts Pkts Drops Errs Media
    In Out In Out
    1/1.1 up 142.2G 261.7G 180.2M 224.9M 11 0 10000SR-FD
    For an interface with no SFP inserted:
    (cfg-sync In Sync)(/S1-green-P:Active)(/Common)(tmos) sh net int 1/1.8
    Net::Interface
    In Out In Out
    1/1.8 miss 0 0 0 0 0 0 none
  • Sorry I should have listed my specific device version, I'm running 10.2.3.
    Thanks,
    Bob
  • I don't think any device has a way of determining if a cable is plugged in or not. Zero traffic does not mean one isn't, it just means the link has never come up.
    Is there no-one at the remote site who could check for you? I assume if there are no cables you'll need to attend to attach some anyway no?
  • With Cisco devices you can issue a show interface command and get information that can help you know determine one way or the other if there is a cabled plugged in. Doesn't say it's plugged in, but I can resonable assume that if it says protocal up then I know there is a cable plugged in.
    I did find: "b interface show" but it doesn't really go indepth more than the GUI.
    Guess I'm making a drive.. :-)
    Thanks,
    Bob
  • hoolio's avatar
    hoolio
    What does 'tmsh show net int all-properties' show?
    You should see 'ms' or 'miss' for an unpopulated port, 'down' for a port with a cable plugged in and 'up' for a port that's connected and up.
    Aaron
  • Thanks Aaron.. the out put shows:
    1.6 down 0 0 0 0 0 0 0 0 0 0 0 none tx-rx none detached
    1.7 down 0 0 0 0 0 0 0 0 0 0 0 none tx-rx none detached
    Looks as if I've got something plugged in..
    Bob
