Nikson_M
Cirrus
Jan 08, 2025"Chassis fan unknown status." logs on a virtual F5 device.
Folks, I am trying to understand why would an virtual F5 device give FAN related errors.
Any idea?
I do not have much details for now as one of the customer has this issue. All I got to know was virtual F5 gives FAN errors.
Hi Nikson,
Ensure the BIG-IP VE software is running the latest version or patch. Check the release notes to see if this is a known issue.
Br
Aswin
probably the virtualization host adds virtual fan or virtual acpi power management device into the vm config.
i suggest you check on it.
