mkallighan_6250
Sep 02, 2011Changing Mgmt port settins on a LTM through GUI
Is there a way to change MGMT port duplex settings on a LTM running 10.2.1? I am not familur with linux or tmsh or b commands. Was hoping to use GUI.. Thanks
- nitass
Employee
can u try?root@edelweiss(Active)(tmos) modify net interface mgmt media ? Values: 10000ER-FD 10000LR-FD 10000SR-FD 10000T-FD 1000LX-FD 1000T-FD 1000T-HD 1000X-FD 100TX-FD 100TX-HD 10T-FD 10T-HD auto no-phy none - vaibhav
for GUI you can go to interfaces under system ....you wont be able to see it directly in interfaces so click on stats and then you can see the mgmt ports as well in the list.....then you change the duplex setting on mgmt interfaces - vaibhav
