Eric_Stewart_36's avatar
Eric_Stewart_36
Oct 09, 2018
Changing Management Address on F5
I have been asked to change the MGMT IP address on two of our F5s that are in a HA pair. Will changing the IPs break any of the communications between the two or is the change communicated between the devices?
Eric
  • It depends how they are configured to do HA - do they have a separate VLAN/self-IP through which they communicate for network failover? If so then it should not cause an outage.
  • Yes, It will break the communication and you might need to establish device trust also. Suggest you to change the mgmt IP during non-business hour.
