Prince's avatar
Prince
Sep 07, 2017
Change load balancing method using iRule
Hello Experts,
I have a requirement where i need to change the load balancing method based on some specific request header.
Current Config:
  • VS with destination persistence.
  • Default load balancing method of least connections.
Requirement: - Because of current configuration we are observing that when traffic is coming to the VS for a specific domain, it is going to 1 of the pool members and making the load on the server to 100%.
I would like to use iRule to remove the persistence and also change the persistence method to RR only for this specific request.
Appreciate your advise on this :
if { [string tolower [HTTP::host]] equals "http://www.abc.com" } {
persist none
