James_Ramsey_10's avatar
James_Ramsey_10
Oct 20, 2005
Certiicate Required
I would like to create a public website, but require one of the company ssl certs to load the site. Does anyone have any examples on how to do this.
Here is an example.
I want to go to https://place.company.com. I want to check to make sure the user has the cert installed on his local machine and then load the site. IF the user doesn't have the cert, I want to send him to a different UI.
Thanks for the help.
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    Assuming you're the issuer of the cet, I think you'd want something like this:
      if { [SSL::cert issuer] eq "your_company" } {
        pool appropriate_ssl_pool
        HTTP::redirect "http://www.your-chosen-redirect-domain.com"
    Hope this helps,
    -Colin
  • This is what I have
    if { [SSL:Thawte Server CA:] eq "Thawte Server CA" } {
    pool secure.sitename.com
    It gives the following error.
    01070151:3: Rule [_require_cert_sites] error:
    line 2: [undefined procedure: SSL:Thawte] [SSL:Thawte Server CA:]
    Colin_Walker_12
    Historic F5 Account
    Well, first of all, the rule is a little off. Try this:
      if { [SSL::cert issuer] eq "Thawte Server CA" } {
    Second, what information in the cert is it that you want to use to identify whether or not the client has the right cert installed?
    Thanks,
    -Colin
  • Here is what i am bascily looking for.
    I have a site, its called https://csr.sitename.com. This is a public site, but I only want users that have one of our certs installed to load the site.
    I though I could create a rule to check to see if the browser has the cert, and if it does allow the user to see the site, and if not, send them elsewhere.
    Here is what I have from your last post.
    HTTP::redirect "http://www.yahoo.com" }
    I recevie the following error.
    line 2: [wrong args] [SSL::cert issuer]
  • I am not sure what part of the certificate I Should look for. I got the rule to work with no errors, but the site will not load with the cert installed.. Any other ideas?
