Bayan_El_Ameen1
Apr 25, 2012Case Insensitive for ASM URLs
Dears,
I have a client application with case insensitive URLs and ASM is case sensitive with URLs.
So, if a client types a URL other than the one learned by ASM then s/he will be blocked.
I think that a trick can be done in iRules by tolowering all requested URLs before sending them and learning them by lower case.
But I want to know if there's an option to make the learned URLs case insensitive in ASM.
Thanks,
- Ido_Breger_3805Historic F5 AccountHi Bayan,
Case Insensitive policies are part of V11.0, if you can upgrade, that would be best as you can benefit from this and other new features. If you can't then go with iRule route.
Cheers,
Ido - Bayan_El_Ameen1
Thanks Ido
