pzhang_366215's avatar
pzhang_366215
Jul 11, 2018
Can not start up mitaka "f5-oslbaasv2-agent", please help.
Hello,
I deployed a Mitaka all-in-one OpenStack environment with f5lbaas-driver and f5lbaas-agent by using some configurations of local.conf like this
enable_plugin f5lbaas-agent https://github.com/F5Networks/f5-openstack-agent.git mitaka
Then I followed the guide and complete some icontrol IP/username/password configuration.
However when I tried to start up f5-oslbaasv2-agent manually by using the command:
f5-oslbaasv2-agent --log-file /var/log/neutron/f5-openstack-agent.log --config-file /etc/neutron/neutron.conf --config-file /etc/neutron/services/f5/f5-openstack-agent.ini
it always reports the error like below:
Begin --log-file on f5-oslbaasv2-agent...
/usr/bin/f5-oslbaasv2-agent: line 361: log_daemon_msg: command not found
I compared version Queens and Mitaka f5-oslbaasv2-agent, I find they are totally different.
I guess I did not type the correct f5-oslbaasv2-agent command, I try to find the correct way to manually on the website, but I can not find it.
Please help, thanks in advance.
