Can I use an LTM HTTP Monitor to monitor a DNS Entry?
Problem is that I have to use the F5 to Load balance outgoing internet traffic out of two firewalls. I've set up a group with both firewalls in it and a virtual server set as a Performance (Layer4) with a source & destination address/mask of any and service port of any and tied it to the pool. So far, so good. However, one of the health monitors that I would like to set up is an HTTP monitor to a website (see below), I would like to set the destination as a DNS entry rather than an IP address for he obvious reason that the IP may well change! I have entered in the DNS name in the Alias-address but it just resolves it and sticks the IP address in.
Is it possible to do what I want or shall I stop losing hair over it and think of another way of testing the route out of both firewalls.
Thanks in advance!
ltm monitor http Check-W3C {
adaptive disabled
adaptive-divergence-type relative
adaptive-divergence-value 25
adaptive-limit 200
adaptive-sampling-timespan 300
app-service none
defaults-from /Common/http
description none
destination 93.184.220.20:http
interval 5
ip-dscp 0
manual-resume disabled
partition Test
password none
recv "HTTP/1.1 200 OK"
recv-disable none
reverse disabled
send "GET / HTTP/1.0"
time-until-up 0
timeout 16
transparent enabled
up-interval 0
username none
- Arie
Altostratus
You should be able to do this with an external monitor. However, another option would be to create a helper-VIP on which you can then run an iRule that checks the remote location. The HTTP-monitor can then simply be pointed at this helper-VIP.
