call tmsh from irule for pool/monitor stuff
hi,dear irule
when lb failed triggered,and pool member is down,how can I get the info for which monitor marks pool member down and get the content of this monitor in irule?
read some posts,it seems there is one way to call tmsh commands/shell script in irule
could u kindly paste an example here?
- Robert_47833
Altostratus
any suggestion? how to get monitor configuration(failed one) via irule?
- nitass
Employee
i do not think it should be done in irule.
sol13898: Determining which monitor triggered a change in the availability of a node or pool member (11.x)
https://support.f5.com/kb/en-us/solutions/public/13000/800/sol13898.html - Robert_47833
Altostratus
hi,Nitass glad to hear from you again
hmm,I know how to check it in logs
but I want to get the info from irule or other place which I use http::respond to send back to broswer
searched many posts,it seems sideband can achieve this
pls advise
- nitass
Employee
i do not see anywhere else besides log which shows name of health monitor that marks a pool member down. so, it is not going to be straightforward to do.
- Robert_47833
Altostratus
Hi,Nitass
Yeah,there is no straightforward way to do this.
I kind of achieve this via code below.
proc send_to_sideband { data } { this is the sideband processing procedure (function) set sbserver [connect -protocol TCP -timeout 500 -idle 10 -status conn_status "ip:port"] send the sideband request send -status send_status -timeout 500 $sbserver $data return the sideband response return [recv -status recv_status -timeout 300 $sbserver] } when LB_FAILED { set current_pool [string range [LB::server pool] 8 end] set pool_member [LB::server addr] set pool_member_port [LB::server port] set pool_member_status [LB::status] set req "GET /mgmt/tm/ltm/pool/$current_pool/ HTTP/1.1\r\nHost: localhost\r\nAuthorization: Basic anVjYW86Q2pqNTUxNjI1OTk=\r\n\r\n" set sb [call send_to_sideband $req] log local0.alert "sb is $sb" HTTP::respond 200 content [subst -nobackslashes [ifile get f5_new_txt]] }it is sideband ,I reused code form other contributor in this forum(Thanks).
but I am not sure whehter I can use icontrol command here since RESTAPI never give me a formatted response and it is difficult to filter out which monitor cause this pool down.
- nitass
Employee
i do not think tmsh/rest provides health monitor name which marks a pool member down.
- Robert_47833
Altostratus
| Reason : udp: UDP recv: connection refused @2015/04/25 02:33:20.?
@(slcq013lba040)(cfg-sync Standalone)(Active)(/Common)(tmos) show ltm pool xxxx_443 members --------------------------------------------------------------------- Ltm::Pool: xxxx_443 --------------------------------------------------------------------- Status Availability : offline State : enabled Reason : The children pool member(s) are down Monitor : 1-Check and xxxxxx Minimum Active Members : 0 Current Active Members : 0 Total Requests : 3 Current Sessions : 0 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -------------------------------------------------------------- | Ltm::Pool Member: 1.1.1.1:443 -------------------------------------------------------------- | Status | Availability : offline | State : enabled | Reason : udp: UDP recv: connection refused @2015/04/25 02:33:20. | Monitor :xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx (pool monitor) | Monitor Status : down | Session Status : enabled | Pool Name : SLCQ013-STC_443 | IP Address : 1.1.1.1|
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx (END)- nitass
Employee
have you tried to have multiple monitors? i understand tmsh won't tell which monitor marks a pool member down. - Robert_47833
Altostratus
yeah,it can show the monitor ,but after I added other monitor ,it didn't show me the correct info,it shows the old monitor which marks pool down.... -------------------------------------------------------------- | Ltm::Pool Member: 1.1.1.1:443 -------------------------------------------------------------- | Status | Availability : offline | State : enabled | Reason : udp: UDP recv: connection refused @2015/04/25 02:33:20. | Monitor : test-Check and /Common/m1.1 (pool monitor) | Monitor Status : down | Session Status : enabled | Pool Name : xxxxx | IP Address : 1.1.1.1
