TNY_122436
Jul 10, 2013C2400 Viprion Blade addition Issue
I have two 2100 blades on a C2400 VIPRION chasis. Do any of you run into issues where when you reboot the blades, sometimes the 2nd blade becomes the primary and vice versa. Is there a way to hard set so slot 1 is always primary? I have a management cable going to the mgmt port on slot 1 and if the 2nd blade becomes primary, I can't https into the gui.
- nitass
Employee
Is there a way to hard set so slot 1 is always primaryi am not aware of it.
I have a management cable going to the mgmt port on slot 1 and if the 2nd blade becomes primary, I can't https into the gui.you can access gui through tmm selfip. anyway, you should wire mgmt cable on all blades. - Josh_41258
Yes, you should cable management interfaces for each blade, and the UI should be accessed via the cluster management IP.
Josh
