Tom_Lauwereins_
May 27, 2014Build custom monitor with specific Source Ports
I'm looking for a manner to build a specific monitor that uses not the random source port or ICMP ID. Is it possible to specify the range of ports the LTM is using for a specific monitoring?
KR
Tom L
- PK_Bhatia
I don't think you can specify more than one port for a monitor. but you can assign more than one monitor to a VIP.
- nitass
Employee
there is rfe. you may open a support case to see if you can expedite it.
ID386525 - RFE: LTM: Monitors: Option to specify source port (or range) in TCP Monitors
