bootable iso USB
hi everyone, When i want to create bootable iso by using mkdisk, I got a fallowing errors; [root@localhost:NO LICENSE:Standalone] cd ./mkdisk argument is not an RPM package cpio: premature end of archive Can't open perl script "/tmp/mkdisk.O11786/usr/lib/install/umdinstall": No such file or directory
- Shaun_Simmons1
Altostratus
Assuming here: You are not in the correct directory.
Step 1: mount -o loop BIGIP-10.1.0.5399.0.iso /mnt/cd Step 2: Insert a 1 GB or larger thumb drive in a USB port on the Linux workstation or BIG-IP system. Step 3:C hange to the root directory of the mounted device, run the command: cd /mnt/cd 5. To start the mkdisk script from that directory, run the command: ./mkdisk
